Marks Web Site
Date:  10-31-2009
Number of Hours:  4.50
Manual Reference:  10-6
Brief Description:  Gear leg upper intersection fairing preparations
My brother Bernie dropped by so we worked on the gear leg upper intersection fairings. First we fit the nose gear leg upper intersection fairing and drilled it to the engine lower cowling. Next we fit the left gear leg upper intersection fairing. Then we riveted the nut plates for retaining the left and right main gear leg upper intersection fairings. Lastly we fit the canopy on once more as I had received the tow bar I had ordered and parked the aircraft nose first into the garage where the canopy open position would not hit the garage door opener rail as it did with the aircraft parked tail first in the garage.
Nose landing gear leg upper intersection fairing drilled to the bottom of the engine cowling
Left gear leg upper intersection fairing drilled to the fuselage
Canopy reinstalled
Canopy reinstalled
